Heldbaum
- Jan 27, 2017
- 128
Hi folks
I have a problem and I would need your help to solve it - Contractor needs to do two openings in a hoist beam at elevator room level to run ropes from the motor - they encroaches onto the machine beam by 4" ( almost half of the flange width, beam is W14x68, 9' long).See attached sketch. They need to know if they can do that and what reinforcement would they need to use to make it possible (if any neeeded). I know reactions at the ends of the beam. I'd need to check if approx. 6" out of 10" overall flange width would work, if not, design the reinforcement, correct? Any thoughts? Do you know of any guides or examples that would be helpful ?
Thanks a lot for your help!
