ManyQuestions123
- Feb 16, 2024
- 3
Hello guys,
I work as a maintenance engineer in a pulp mill. I'm planning on replacing a 65mm diameter FRP pipe that currently has a 4 way fitting shaped like a cross, but I need to change it to a 4 way fitting that looks like an L/T, but my contractor is telling me that this might be to fragile.
What's your opinion? The only standard I know of (din 16966) only refers to T shaped fitting (3 ways). Should I change the original 4 way to two TS? Or do something like an L/T 4 way fitting?
Thank you in advance.
