geo321
- May 17, 2015
- 85
Hello
I am asking your opinions regarding the below:
2 separate walls are being extended 40 meters up and they are carrying a staircase from one side and an elevator from the other side.
I am planning to brave vertically these 2 walls by 2 isolated beams very 3.5 to 4 meters.
If these beams are located at that vertical grid, what verifications should i perform in order to conclude if these beams are bracing the walls or not ?? In other words, what is the embraced height of the wall ? Is it the vertical spacing between the beams?
To be mentioned that a slab is bracing the top of the 2 walls at the 40 meters height. A quick sketch is attached.
Thank you for the help
