PermanentCharpy
Materials
I am having parts manufactured from AISI 4130 (80KSI Yield). The parts are 9.00" OD x 4.50" ID X 20.00" LNG (approximately, with some internal details, threads etc). The shop making these didn't quote for heat treating after roughout, which I have now requested. I am having a bit of friction with management on whether I actually need to heat treat after roughout, and not just buy material on the hard side to guarantee sufficient hardness (my range req'd is 207 - 237 HBW). This should be fine based on the Jominy curves I have looked at for 4130 - 230 HBW on the surface should probably get around the required minimum of 207 HBW at the core. This is not what I am used to doing, and have typically heat treated anything above the LRS after roughout to guarantee through hardness.
