Thank you for your help. I appreciate it very much. I hope to give you as much information as possible so that we can figure out what is best for our product.
As a an owner / engineer I am always striving to improve our product while looking at the cost. The cost of heat treatment is minimal on the front end and looks like it could be a benefit, but we are worried about the strength / brittleness / toughness of our welded area, if we choose to try this method (method ii).(our current method works very well)
--Our goal is to improve our product, without incurring massive costs, or compimise strength.(maybe even save money, or processing time... a small dream)
Do to our material properties we can not rebore to a good size and finish and therefore incur a very large honing cost due to the amount of material we end up having to remove. The reboring and honing shops "dislike" our soft gummy material.
so...
1) No problem on the cost of heat treatment (minimal lot charge to do raw tubes)
2)
a) What is the difference in locally affected weld zone from our current method;
i) raw non heat treated tube, machine, weld, rebore, final hone.
and our proposed method;
ii) heat treat tube blank, machine, weld, rebore, final hone.
Do we gain, do we lose; strength, brittleness, toughness ?? Does the the weld area become more brittle or less compared to the origianal method?
We have a third procedure that we feel is the best however the machineing cost goes throught the roof. Most shops will not even look at the job, the welded plates make the tube near impossible to machine. iii) descale od, weld plates, heat treat, Machine threads ID, Od both ends, rebore, hone. (we may neer to add a benchining / straightening procedure in there after heat treat)
Hope the information provided gives you a better picture.
Let me know what you think,
AZ
