Steven;
Initial thoughts, open to comments:
Assumptions:
Unity PF, equal %imp of transformers, equal and balanced supply to the transformer bank in question and negligible voltage drop in the primary neutral supply conductor.
Note on open delta; For two identical transformers in open delta, the virtual transformer across the open side of the delta will have the same %imp and regulation as either of the real transformers.
Consider a 100 KVA transformer paired with two 50 KVA transformers.
The single phase load is 75 KVA.
The 100 KVA transformer supplies 50 KVA, 50%, and the pair of 50 KVA transformers supply 25 KVA, 50%.
So each transformer is loaded to 50% and so the voltage drop across each transformer will equal.
Conclusion, the rule that parallel transformers will share the in proportion to their capacities will hold true for a single phase load on a three phase bank within the previous assumptions.
I am still thinking about the case with three phase loads and more particularly, mixed single and three phase loads.
Ohm's law
Not just a good idea;
It's the LAW!
