emissaryx
Automotive
- Sep 29, 2003
- 7
I have a situation where there is a 480V 3-Ph 3-Wire system feeding a location with some 480V motors and controls. There is no neutral pulled so the electrician wants to wire a 277V 4.5kW resistive load (electric heater) from HOT to GROUND to get 277V at the site since there is no neutral. The heater itself is rated for 300V.
I know this is not the usual or preferred way to get 277V out of a 480V 3PH system.
What are the negative effects of using this setup (480V to GROUND = 277V)?
