4th Axis Machining Geometry
Siress
Industrial
Jan 11, 2006
20
0
0
Hello all,
I am trying to model a rather complicated part exactly as it should be produced. Imagine an hour glass shaped cylinder that is machined via 4th axis with a sine wave. I can easily make this cut on a surface, but the new surfaces formed are what trouble me. I have tried surface lofts, but I lose the control of the geometry that I need. Basically, what command options do I have to make these new surfaces accurately (accounting for the geometry of the cutting tool)? If I could do a swept cut that somehow stayed perpendicular to my rotational axis, that would be great; but I don't know how to make this happen.
Thanks!
Siress
Hi, TheTick:
I took a look at the model you created. How do you know that the ruled surface created based on the 3D sketch (on surface spline) is normal to the cylinderical surface?
Best regards,
Alex
That is how the ruled surface is defined. Check the options when creating the ruled surface. (I don't think it can be changed after creating.)
Hi, TheTick:
Thanks for the quick reply! My point is that the ruled surface has not knowledge of the cylinderical surface. When you created the ruled surface, you did not pick the surface. You only pick the 3D sketch.
Best regards,
Alex
