blueandwhiteg3
Computer
I'm exploring the idea of putting together my own parabolic dish(es) for special applications where off the shelf is not satisfactory. The transmitter would not put out more than 28 dBm around 6 GHz.
I would like some suggestions / ideas / input on the material selection and its response in terms of RF. One of the factors is my workability of the material.
Here are some of the ideas that have come to mind:
- Cold cast rf-neutral polymer resin filled with metal powder or particles. Magnesium might they might be a good choice for weight and settling issues. How effective? How much? What particle size?
- A thin layer of aluminum foil over my choice of rf-neutral non metal substrates. How thick for the foil? How effective?
- Aluminum sheet. Once again, how thick, how effective? Does the alloy matter?
- Copper foil or other metal foil - would something other than aluminum be more effective?
- Soft steel sheet - how does this compare to aluminum in terms of effectiveness? How thick?
- Other metal sheets - is there something else I should consider, which would be workable?
