Onesandnoughts
Computer
- May 1, 2002
- 4
I have a compressor fitted with a 230v 60Hz single phase cap-start, cap-run motor. It is meant to run at 3450 rpm. Although it will run here in UK on 50Hz, after a couple of minutes the caps begin to smoke! I think that the reduction in operating frequency means that the motor does not reach sufficient speed for the centrifugal switch to cut out the start side. Apart from replacing the motor, is there anyway to solve this ?
