ChrisDuncan
I need a torsion coil spring rated up to 1100 lbs. but design space is limited to 4" Diameter x 48" length.
The range of motion needs to be 11 revolutions.
Is this possible? If not 1100 lbs. then what is the maximum rate spring that would fit within this size?
