747-8 aborted take-off test
Saw it - amazing. Stopping something that heavy in just a few thousand feet!!
Very cool test. Brakes glowing red hot. I wasn't sure if I saw a few licks of flame or if that was just the glow from the discs.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
thanks for the link, this is impressive
Ben
Nacelle Stress Engineer (repair on Civil Aircraft)
Wonder what the A380 equivalent looked like?
I wonder if this test included the extra 30 tons or so of passenger and luggage weight?
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
I guess I had the sound turned off. Thanks.
Mike McCann
MMC Engineering
Motto: KISS
I notice the tires are flat after the test. Someone told me that the pilot can deflate the tires. Is that just done to lower the plane in a controlled manner to the tarmac rather than letting the brake heat cause a blowout and subsequent rapid drop?
Those tires and/or wheels generally incorporate a thermal fuse that blows out or melts when things get a bit too warm....
Steve R.
Pretty sure the tire deflation was explained in the commentary, I think 49again is correct from what I remember.
