7SJ80 restore settings
IPopov
5
I have a problem with the existing settings in one Siemens relay 7SJ80. It is always tripped and it is not possible to change the settings. So, I want to ask you if there is some option to restore the device setting to default with keyboard combination. I know such method for MiCOM devices, so I think that it is possible.
Thank you in advance,
Ivo
I have the same problem with 7SJ80. It is always tripped. Is there some trick to reset the factory settings?
I did not find a way to restore the settings, but there is way to block some of the functions when they are tripped. it depends on which function is tripped.
Which one is in your case?
