jskernahan
- Jun 27, 2012
- 15
Hi All,
I have a piping spec that does not allow 8" or larger globe valves and insists on a v-ball or gate valves as an alternative. I'm not sure the reason for this and am wondering if anyone has any insight? Below are the spec conditions:
Flange rating: 600# (max pressure: 10,210 kPag @ 38 deg C)
Code: ASME B31.3
Temp range: -45 deg C to 260 deg C
Service: Low temp sour process (NACE)
Corrosion Allowance: 3.0 mm
Code: ASME B31.3
