ElCidCampeador
- May 14, 2015
- 274
Hi, how is it possible to calculate a skirt of a vertical pressure vessel (designed acc. to ASME VIII Div.1), where the skirt is not completely welded to the vessel for 360° but only for 300°?
Skirt is a rolled plate but hasn't longitudinal seam because edges are not welded to each other...it's not a circular opening it's a complete vertical access to the bottom of the vessel. In other words, skirt is welded to the head with a circular joint of 300° arc.
I checked different softwares but I still haven't found one that allows this calculation.
Now I'm designing this kind of vessel and I'm trying to find a way by formula to check if the calculation for 360° skirt is still valid for my case.
Do you have any reference? Do you have suggestions? I would create something like an excel file (with right formulas) that I could attach to main calcs to validate my skirt...thanks
