MEDK
- Dec 20, 2006
- 11
Piping Code B31.3.
Material for butt weld fittings ASTM A-403 Gr WP 304.
Impact Testing Requirement at -325 °F Design Temp.
From reviewing the piping code for this material, it appears that for EFW fittings, the base metal will be exempt from impact test requirements. However, the welds for an EFW fitting will require impact testing unless the weld procedure qualification welds can pass the impact requirements at the design temperature. If this is correct, the question has come up, how to confirm that the supplier of the fitting meets the design temperature requirements without specifying seamless fittings only? Currently our piping specifications allow both seamless and EFW butt weld fittings. Is there a way to check that the fittings used by a piping contractor will be suitable for the application?
A search of this forum did not indicate past posts for similar topics unless I missed them.
Thanks,
DK
Thanks,
DK
