aijazblr
Petroleum
- Sep 5, 2009
- 4
Seeking guidance on controlling a Rexroth A A10VSO variable displacement pump.
I have this A10VSO pump that is used to power a closed centre hydraulic machine with multiple actuators (pistons and motors) operating at 2500 psi. The pump was recently replaced and I believe has not been set up correctly.
Although the pump nameplate says it is a DFR1 (pressure/flow control), there is no external line between the pump discharge and the pilot valves mounted on the pump.
The pump puts out a constant 2500 psi and maintains the pressure whether the machine is in use or in neutral, consequently the system overheats as there are long periods of machine inactivity with the pump running at 2500 psi.
With the DFR1 control, is the pump pressure supposed to drop to a lower idle pressure when the machine is in neutral? If so, how is this achieved?
How can I set up the pump to sit at an idle pressure with zero output and switch to 2500 psi on demand when the machine is moved out of the closed centre position?
Thanks in advance for your guidance.
