batman2010
- May 28, 2010
- 31
I used to believe that a circuit breaker in panel can be used as a disconnecting means for motor loads like in boiler rooms when the panel is within site until i read Article 430.109 in the NEC (NFPA 70) defines the type of disconnecting means allowed for motors and controllers. I am concluding that it is against the code for a circuit breaker in panel to be considered used as disconnecting means unless it is in a separate enclosure and can be locked in an open position, any body have an input on that?
