hemiv
- Dec 7, 2018
- 82
Hi all.
I'm working on a small residential renovation project. This is a late 19th c. brick building. The project is on the interior of the building, and a lot of the walls are covered with gypsum board or painted. I've worked on similar buildings, but none with this much involvement with the brick itself. A few questions:
[ul]
[li]Should I be requiring ASTM C1314 prism testing? There are a few pockets to be made for new beams, and this brick could be used to make test prisms. I'm keeping the new bearing stresses below 100psi.[/li]
[li]If not, I would like to check the masonry with some non-destructive testing. Do you do this? What kind of equipment is accessible? I'm aware of rebound hammers, but I've never personally used them to approximate strength, and am more familiar with them being used on concrete.[/li]
[li]Similar question for the mortar. I am requiring testing to confirm the cement to lime ratio in order to specify the new mortar, but should anything else be done?[/li]
[/ul]
[ul]
[/ul]
