I recently got a project to certify a cementing head. What API spec or ASME code this should be designed to? Would I be wrong to assume API 6A?
Secondly, in API 6A 4.3.3.2 it states Sec VIII Div 2 Appendix 4 may be used for design calculations for pressure containing equipment, and it gives equations St=0.83Sy and Sm=2/3Sy. I assume I need to plug these values of St and Sm into equations in Sec VIII Div 2 to get my allowable internal pressure or wall thickness? But we do not have Div 2 in our office, but we do have Div 1. Can anyone tell me if the equation in Div 2 is the same as Div 1 UG-27 equation (1)? And I can simply insert St or Sm into the Div 1 equation?
Mark
Mark
