takio
- Jul 9, 2019
- 37
Hello
The two A-frames stands side by side and linked by the top cross beam and middle cross beam.
and the middle bar has a rod sticking out at the center. Force is applied at a distance D from the middle bar.
I wanted to calculate the internal forces in the beams AC, CB, and AB.
I think I can calculate forces using 1)+2), using truss analysis (method of joints). Am I on right track?
For 1)
F= W/2
For 2)
M=WD,, But I have also M=W/2*L, and theses two has different directions. This gets me confused.
Would you give me some ideas on the calculations?
Thank you
For 1)
F= W/2
For 2)
Thank you
