A journal to able to place things on reference sets based on their layer.
mmiscool
34
I am looking for a solution to a problem I have been facing.
We have a some complex rules for what is supposed to be on specific reference sets. We already have a layering convention that captures the same type of information so I would like to take that and use it to make and populate several reference sets.
Something like take all objects on layer 35 and place them on the “access space” reference set.
Does anyone have any kind of code that might do this?
Something like this?
Code:
Option Strict Off
Imports System
Imports NXOpen
Module Module1
    Dim theSession As Session = Session.GetSession()
    Dim workPart As Part = theSession.Parts.Work
    Sub Main()
        If IsNothing(theSession.Parts.Work) Then
            'active part required
            Return
        End If
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Const undoMarkName As String = "reference set from layer"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
        Const refSetLayer35 As String = "ACCESS SPACE"
        Try
            Dim myRefSet As ReferenceSet = CreateReferenceSet(refSetLayer35)
            Dim layer35Objects() As NXObject = workPart.Layers.GetAllObjectsOnLayer(35)
            myRefSet.AddObjectsToReferenceSet(layer35Objects)
        Catch ex As NXException
            theSession.UndoToMark(markId1, undoMarkName)
            MsgBox(ex.Message)
        Finally
        End Try
        lw.Close()
    End Sub
    Function CreateReferenceSet(ByVal refSetName As String) As ReferenceSet
        Dim theRefSets() As ReferenceSet = workPart.GetAllReferenceSets
        'does the specified reference set exist?
        'if so, return it
        For Each someRefSet As ReferenceSet In theRefSets
            If someRefSet.Name.ToUpper = refSetName.ToUpper Then
                Return someRefSet
            End If
        Next
        'if we get here, the ref set does not exist
        'create it
        Dim targetRefSet As ReferenceSet
        targetRefSet = workPart.CreateReferenceSet()
        targetRefSet.SetName(refSetName)
        Return targetRefSet
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
    End Function
End Module
www.nxjournaling.com
That was exactly what I needed. Thank you.
I modified the code as follows and made a sub that places objects on the layer.
I need to find a function that will empty a particular reference set so that each time the script is run it makes sure that there is nothing on a particular reference set before populating it.
Any one have any ideas.
Code:
Option Strict Off
Imports System
Imports NXOpen
Module Module1
		'SetRefByLayer("ref set name", layer number)
	Sub Main()
	SetRefByLayer("ref set name", 100)
	end sub
    sub SetRefByLayer(ByVal referencesettosetto As String, ByVal layertosetthingsto As double)
            Return
        End If
        lw.Open()
        dim refSetLayer As String = referencesettosetto
        Try
            Dim myRefSet As ReferenceSet = CreateReferenceSet(refSetLayer)
            Dim layer35Objects() As NXObject = workPart.Layers.GetAllObjectsOnLayer(layertosetthingsto)
            myRefSet.AddObjectsToReferenceSet(layerObjects)
            MsgBox(ex.Message)
        Finally
        End Try
        lw.Close()
    End sub
        'if so, return it
                Return someRefSet
            End If
        Next
        'create it
        Return targetRefSet
    End Function
    End Function
End Module
Assuming you have a reference to your reference set named: theReferenceSet, the following should work
Code:
theReferenceSet.RemoveObjectsFromReferenceSet(theReferenceSet.AskAllDirectMembers())
This line was taken from a journal I have that shows all the reference set members on screen and allows the user to select entities to add or deselect entities to remove from the reference set.
