SteveShakeshaft
Hi all, I'm in a facility where we have about 1400 actuated ball valves, all 3". Many of the duties (for example) are on service manifolds, Steam on one side (~ 160 deg c) when closed with Chilled Brine (-10 deg c) Cooling water (~0 deg c) or other fluids (air, nitrogen etc) on the other. There is a fair degree of scale and rust also floating around the piping. The ball valves are regular carbon steel bodies and stainless steel balls with filled PTFE seats. Many of the valves are changed regularly on a breakdown basis, upto 8 times a year. I'm looking for a robust ball valve that will seal when used about 40 operations per day for two years under such ardous conditions. A metal seat ball valve with a hard ball perhaps? I want to move to a planned regime of overhauling all the valves after two years operation. Services cross contamination is also a big problem right now.
Thanks.
Steve.
Thanks.
Steve.
