1
- #1
SKIAK
- Mar 18, 2008
- 145
I'm holding in my hands an A325 3/4" diam heavy hex bolt 1-3/4" long, and also an A325TC 3/4" diam 1-3/4" long. So far as I can tell from AISC, the length these bolts are equal. Looking at them from the side it would appear that the TC bolt only has complete threads out to approx 1-1/2" (before it tapers off) where the heavy hex bolt has about 2 more threads.
This is something that came up in the field. The contractor felt after installing the specified TC bolts that they weren't long enough and ordered longer ones. They are asking me to justify that the detailer specified the wrong length of bolt. AISC says the end of the bolt only needs to be flush with the end of the nut, which it was. I only bring up the heavy hex to compare with the TC, with the differences in threads I find it difficult to say the effectiveness of these two bolts is equal.
The bolt manufacturer stated that only 1 to 3 threads in the nut actually end up taking load and that is all that is required to fully engage the bolt. I can't find anything to back this up.
In reality, it seems to me that AISC says its OK since it does not mention that all threads need to be engaged. However I find it strange that one bolt would have less threads and still be considered equal from a specifying standpoint. Thoughts?
