mikeCTE
- Feb 21, 2014
- 42
In AASHTO section 13.8.2, it discusses pedestrian railings as it pertains to the application of LL and WL.
I am curious about the case where you have a chain link fence that has no top 'rail' - only a tension wire. See attached for example from WSDOT.
The tension wire is clearly incapable of resisting 200lb point load + 50plf for the LL case. Thus, my conclusion is that for the sake of design checks, we should only look at the post and the post should only be sized for the AASHTO recommended 15PSF WL applied to the surface area of the chainlink. I do not think we should apply the LL case on the post.
Is there general consensus on this topic on the eng-tips forums?
