I am designing an "at grade" (Cover < 2'-0") RCB using AASHTO LRFD.
The State DOT I am in specifically requires us to use LRFD for RCB's. The LRFD Code only requires the full analysis for HL93 and Lane Load if the supporting walls are > 15 feet apart. I am designing a Triple 10'(W)x6'(H) reinforced concrete box and the code says "Where primary strips are transverse and their span does not exceed 15.0 ft.-the transverse strips shall be designed for the wheels of the 32.0-kip axle."
I am trying to understand how to apply this load, as stated above.
I have a three barrell box and I am wondering if that 32 kip load is acting alone and moved across the three spans for maximum forces or is it multiple 32 kip loads at some (14'?) spacing moved across the three cell spans?
[I would also be interested in any software that anyone has had success with.]
Thank you
Thank you
