Abaqus-CAE : Circular footing soil as Spring
shubbad
23
"I have modeled the wind turbine foundation. I have modeled the soil as a spring and applied vertical load, horizontal load, moment, and non-uniform pressure using Analytical field and gravity load. For the spring, I have set the stiffness using a connection to the ground (Standard) with DOF = 3. However, when I am running the model, it is showing an error. I have asked someone, and they are telling me it is not converging due to an equilibrium error, but I don't know how to correct it." I am using Abaqus Software for the Analysis.
 https://files.engineering.com/getfile.aspx?folder=3011767c-335f-497b-b6f0-a34d3a3f753d&file=Screenshot_2023-09-25_222221.png
You can create a geometry set, no need to operate directly on the mesh. Internally, such a set will be converted to node/element set.
