StructEngineer25
I am modelling a column with pin ends,using an eigenvalue analysis
i) End plates are rigid bodies
ii)Column is a shell element
I need to create an accurate interaction of the column(shell) and the end plates(rigid),but i am failing to get it right.
I used a surface to surface interaction connection.
