Abaqus early termination in an inflation simulation with ALE
Jay2010
Bioengineer
Jan 22, 2010
6
Hi all,
My Abaqus/explicit ALE simulation terminates before the target pressure load can be achieved. The geometry is consisting of 4 concentric circles, and one other circle which will be inflated with a pressure (DSLOAD). Due to this expansion, ALE is used to control mesh distortion. I have made the whole domain as the adaptive region. I have used very small incremental and performed mesh sweep at frequency=1. But the simulation still terminates early. I wonder whether you can check the attached inp file to see whether I have made mistakes or where I can make improvement.
I really appreciate your help!
Jay
I ran your job and I think it is erroring before any remeshing will occur. You might want to increase the remeshing frequency. Also, a linear elastic material model is probably not appropriate for this large deformation. What is this modeling? I hope this helps.
Rob Stupplebeen
Hi Rob, thanks for replying! The model is used for human tissue,with uncertainty in mechanical properties (due to the non-invasiveness). I just start with simple elastic materials.
I have already made the remeshing frequency of ALE to 1 with 10 sweeps. Do you think what may be wrong? It seems that you think I have some flaws that I am not aware of.
I believe that the deformations were too large and caused the solution to fail before a remeshing was performed. I could not remesh because the INP is just an orphan mesh. Next time if you post your CAE I can probably be more help.
With these large deformations almost no material is linear which is the assumption of the material properties you are providing your model. Look into hyperelastic material properties like "Neo Hooke" I hope this helps.
Rob Stupplebeen
