Julian2w2w
I am doing the simulation of simple shear of a square using quadrilateral element type for the mesh. The material properties being Neo-Hookean.
The abaqus error message and warnings are like follows:
'RELAX STIFFNESS IS NOT A VALID CHOICE FOR THE HOURGLASS PARAMETER ON THE *SECTION CONTROLS OPTION IN Abaqus/Standard; HENCE, IT WILL BE REPLACED WITH HOURGLASS=STIFFNESS FOR THE CURRENT ANALYSIS. THE ORIGINAL CHOICE WILL, HOWEVER, BE STORED FOR ANY SUBSEQUENT Abaqus/Explicit IMPORT ANALYSIS
The parameter hourglass = stiffness on the section controls option is relevant for these elements: c3d8r, cax4r, cgax4r, cpeg4r, cpe4r, cps4r, m3d4r, m3d9r, s4r5, s4r, s8r5, s9r5, sc6r, sc8r and their hybrid, thermal and pressure counterparts wherever applicable. It is also relevant for all types of modified triangular and tetrahedral elements. This warning can be ignored if the feature is applied to these element types only.
DISTORTION CONTROL PARAMETER FOR THE *SECTION CONTROLS OPTION IN Abaqus/Standard IS VALID ONLY FOR C3D10HS ELEMENTS AND WILL BE IGNORED FOR ALL OTHER ELEMENT TYPES IN THE CURRENT ANALYSIS. IT WILL, HOWEVER, BE STORED FOR ANY SUBSEQUENT Abaqus/Explicit IMPORT ANALYSIS
Excessive distortion at a total of 5 integration points in solid (continuum) elements'
I tried hourglass distortion control but it didn't work.
