Abaqus error in in keyword *BOUNDARY
Tinni1
157
I am doing a three-point bending analysis of a cold-formed steel beam. In the post-buckling analysis using the Abaqus explicit solver, I got the below error:
in keyword *BOUNDARY, file "Job-18.inp", line 55500: Unknown assembly id 2
I have applied boundary conditions at the reference nodes of the rigid plate element , which has been used as the support.
Could anyone please explain what this error means?
Picture of my abaqus model is below:
Sounds like a boundary condition using node number directly, without referring to part/instance number.
Thanks, for your response.
I applied the boundary condition at the reference points of the rigid rectangular plate elements.
What should I do to get rid of this error?
Was the part created as rigid or as deformable and just made rigid via rigid body constraint ? Was the REF point created on the Part or Assembly level ?
The support plates at both end and the loading plate at the top was created as discrete rigid plate elements. The reference points were created at the part level. I have used three seperate discrete rigid plates as loading plate and the two support plates.
Since it's a post-buckling problem, is it an individual analysis or does it use import functionality, for instance ? Were any changed made in the input file or was it completely configured in Abaqus/CAE ?
In the post-buckling analysis, imperfections were imported from the buckling analysis by the edit attribute function in Abaqus CAE in the input file. Is it because of importing the imperfections?
Try without them to find out. Generally speaking, it might be best to export the input file and correct it manually in such cases. Built-in keyword editor can cause unexpected issues.
Great! Thanks a lot. I will try as advised.
