ABAQUS error
jj89
18
Hi every one,
i'm new in ABAQUS, and i'm trying extrude a bar of aluminium thought a square, I don't know why when I submit the job, it doen't work.
I think it is a problem related with the related surfaces.
Could anyone see the attached document of Abaqus.
Thank you too much!
 http://files.engineering.com/getfile.aspx?folder=58fbb372-baaf-4ab1-86d1-38ddb5d18c76&file=22.zip
Your contacts are added in the second step, so in the first step your parts don't know each other and you get rigid body modes.
Thank you Mustaine3!! just to be sure and I understood what you mean, what I have to do is to add the "interactions" in the "initial" step and remove the "interactions" that i did from the step "contacto" right??
