ABAQUS - How can I control two different parts at the same time with VDISP?
bugifa
Hi Everybody,
I have to assign movement to two different parts and both of them should be controlled by VDISP.
I can write the VDISP for each of them (and they both works...separately) but I am not able to control them at the same time.
I tried to use CBNAME to indicate the name of the boundary condition I want to control, but it doesn't seem working (probably I'm using it wrong).
Thank you to whoever will provide help!
Hello bugifa
Did you get your issue solved? I have the same question on control two different parts using VDISP. also may I ask do you know how to save the original coordinates in VDISP? not the current coordinates. Thanks so much.
Best
Lee
Sorry, I haven't still found a way to handle the two parts....
Thanks bugifa, then may I ask how can I save the original coordinates of the nodes in the VDISP?
Best
lee
