Abaqus. How do I make a set of cells using .getCells() on face object?
brianbakmp.aau.dk
Hi
I am trying to make a set of cells that are associated to one or more faces and save them in a set using python scripting for Abaqus CAE, but I cannot make it work. I have created and example that shows what I am trying to do and where it fails. Can anyone help in identifying what I should be doing instead?
from abaqus import *
from abaqusConstants import *
import section
import regionToolset
import assembly
import load
import interaction
import mesh
import section
import job
import visualization
from abaqus import getWarningReply, YES, NO
from abaqus import getInput
import mesh
import warnings
from warnings import warn
backwardCompatibility.setValues(includeDeprecated=True, reportDeprecated=False)
session.journalOptions.setValues(replayGeometry=COORDINATE, recoverGeometry=COORDINATE)
m = mdb.Model(name='getCellFromFaces')
mySketch = m.ConstrainedSketch(name='sketch01', sheetSize=200.0)
pointA=(0.0, 0.0)
pointB=(10.0,0.0)
pointC=(10.0, 4.0)
pointD=(0.0, 4.0)
mySketch.Line(point1=pointA, point2=pointB)
mySketch.Line(point1=pointB, point2=pointC)
mySketch.Line(point1=pointC, point2=pointD)
mySketch.Line(point1=pointD, point2=pointA)
part01 = m.Part(name='Part01', dimensionality=THREE_D, type=DEFORMABLE_BODY)
part01.BaseSolidExtrude(sketch=mySketch, depth=4.0)
part01.Set(faces=part01.faces.findAt(((3.333333, 4.0, 2.666667), )), name='Set-1')
#split the cell in three
part01.PartitionCellByPlanePointNormal(
cells=part01.cells.findAt(((6.666667, 0.0, 2.666667), )),
normal=part01.edges.findAt((10.0, 3.0, 4.0), ),
point=part01.InterestingPoint(part01.edges.findAt((10.0, 3.0, 4.0), ), MIDDLE))
cells=part01.cells.findAt(((0.0, 2.666667, 2.666667), )),
normal=part01.edges.findAt((2.5, 4.0, 4.0), ),
point=part01.InterestingPoint(part01.edges.findAt((7.5, 2.0, 4.0), ), MIDDLE))
# HERE IS THE PROBLEM:
# Getting the the cell id associated with one of the upper faces
cellsID= part01.faces.findAt(((3.333333, 4.0, 2.666667), ))[0].getCells()
print(cellsID)
#trying to make a set containing that cell but do not succeed.
part01.Set(cells=part01.cells[cellsID[0]], name="set of cells")
# returns: TypeError: keyword error on cells
#Also, how do I make a set of the two cells associated with the two upper faces?
# I mean basically doing the same as about but know with two surfaces and two cells
Hi
I found a solution to my problem. It is:
print('\nChoosing faces stored in a set and --> getting the associated cell IDs and making a set containing those cells.')
cellsIDs = []
for face in part01.sets['Set-1'].faces:
cellsIDs.append(face.getCells()[0])
print('cell IDs are: ' + str(cellsIDs)) # --> [0,1]
cellsForSet = part01.cells[cellsIDs[0]:cellsIDs[0]+1]
for i in range(1, len(cellsIDs)):
print('i: ' + str(i))
cellsForSet = cellsForSet + part01.cells[cellsIDs:cellsIDs+1]
part01.Set(cells=cellsForSet, name="set of cells1")
