Hi all,
As the subject, the model is running fine with NLGEOM turned off but as soon as I turned it ON, the model struggled to converge. I have reduced the initial and minimum increment step size and increased the number of attempts (I_A) the solver can reiterate with a lower step size and still no luck getting this to work...
I am doing a multisteps analysis, however, the model can't even get past the first step, in which I pre-loaded the column axially with compression load before loading the end of the cantilever in the second step.
Attached is my Abaqus model if anyone wants to look at it.
Many thanks, folks!
Heng
https://files.engineering.com/getfile.aspx?folder=f417f467-8fa3-4770-8032-cceaf6072728&file=test.jnl
Many thanks, folks!
Heng
