Hello everybody!
I would like to have some help with abaqus concerning the extraction of natural frequencies. I would like to understand the outputs of Abaqus.
I analysing a gas tank made of steel plates. I'm using shell elements S4R to model the tank and I performed a linear perturbation frequency analysis to extract the natural frequencies (eigenvalues).
First, I'm obtaining in a range of 0 - 2Hz a lots (thousands) of modes, which I assume the majority are either local modes either "incorrect" solution of Abaqus. I wanted to analyse the mass participating in the modes, and for that I found the Effective Mass (EMi) for each degree of freedom on Output History of Abaqus. Though, I do not uderstand the values because either they are very small (which can be the sign of local mode) either very high (much higher than the mass of the tank). So, I'm confused. What is this Effective Mass (EMi) that Abaqus provides? What are the units? (If for example I work in kg, N, mm).
Thanks for any help.
Further information concerning the model:
height of the tank =+/- 33m
radius =+/- 29m
thickness of the wall plate = 5mm
thickness of the roof plate = 10mm
Eignesolver: Lanczos
Best regards,
Alexandre
radius =+/- 29m
Best regards,
Alexandre
