ABAQUS read spring force and relative displacement with python scripting
xli
Student
Oct 22, 2023
8
How could I extract the force and displacement results (S11, E11) of all the spring elements in a model? Is it possible to identify the springs through python scripting?
Thank you!
Might be easier to save history output for them and then access it in the database:
Code:
*OUTPUT, HISTORY
*ELEMENT OUTPUT, ELSET=SPRINGS
E11, S11
Of course, you have to define that elset with all spring element numbers.
Thank you! And how can I define elset? I couldn't find their element numbers. Is there a place to look them up?
They will be defined like this:
Code:
*ELEMENT, TYPE=SPRING…
The first number in each data line is element number.
Then you can define an elset like this:
Code:
*ELSET, ELSET=SPRINGS
list_spring_numbers_here
