Abaqus Scripting or Subroutines for simulating an iterative process? 1
Yunus9696
IR
Hello everybody
Hope you’re doing great
Assume I have two material properties MATERIAL1 and MATERIAL2. I start my model with MATERIAL1 and calculate each element’s (von misses) stress and if any element’s stress exceeds N MPA I change its material to MATERIAL2 and continue till all the elements’ materials
are altered to MATERIAL2.
For this purpose:
Do you suggest Abaqus scripting by the following method:
1. Run the job
2. Write elements’ stresses to an .odb file
3. Check the elements’ stresses by reading the .odb file and change the desired elements’ material to MATERIAL2
4. Run the next job
5. Continue the above-mentioned loop by a script till all the elements’ materials change to MATERIAL2
Or
Do you suggest running a job and implementing Abaqus subroutines (USFLD etc)?
1. Which method is applicable?
2. What are the cons and pros of each one?
Thanks for your precious points.
Best regards,
Yunus.
PS: Let’s say the real model has 1000 elements or more and 5 different material properties to describe a small gap bone healing process.
If you want this to be done during the analysis, use subroutines, they are meant for such purposes. With scripting you would have to divide your study into several jobs which is not very convenient and a significant effort would be necessary to achieve the desired goal.
