ABAQUS SCRIPTING AND EDITING 1
Oluwakay
83
Hello Everyone,
I have a question. I am trying to run a python script in abaqus. My question is that, is it possible to edit whatever I want from the software interface like materials constant, orientation, model geometry and lot more OR I have to do all editing from the code itself??
Thank you!
It depends on what your script is doing. If it's only setting something in Abaqus/CAE without submitting jobs then yes. There are also ways to create custom dialog windows for scripts.
Thank you so much for your response. So, does that mean if I have a script that includes job creation and submission, I can't do any editing from the software, but only from the codes then run again??
Thank you!
You could include a prompt (pop-up window) for the user asking for inputs under specific circumstances (check the getInput and getInputs functions) but not freely change anything in the setup at any moment while the script is running.
Thank you so much for your response! However, if I'd like to change any parameters, can I change it within the scripts and run again? Is that also a possibility?
Thank you again!
Of course. Modifying and rerunning .rpy files or recorded macros is a very good way to start with Abaqus scripting.
