Hi all,
I have a model that I want to automatically run multiple times, with slightly different settings. By removing a node from my Tie constraint I can increase the length of a crack in my model. This will give me info on all crack lengths a want!
I want to do this automatically using Abaqus scripting. I want to modify the Set that represent my bonded nodes. As of now this Set is defined like this:
mdb.models['SSD_PEEK'].rootAssembly.Set(name='Bonded_Nodes', nodes=
mdb.models['SSD_PEEK'].rootAssembly.instances['Cutply2-1'].nodes.getSequenceFromMask(
mask=('[#109 #0:8 #ffc00000 #ffffffff:9 #0:18 #fff00000 #ffffffff:5',' #7f ]', ), ))
Is there a convenient method for defining a set of nodes? So some other way then using getSequenceFromMask(). Or can someone explain how the getSequenceFromMask() function works?
Hope you guys can help!!
Thijs
Thijs
