MM13
Student
- Jun 15, 2023
- 1
Hi everybody,
I want to optimize the thickness of a shell-modell to get the weight-specific stiffest solution.
The problem is that i have no target volume/weight. The only constraint is that my shell-thikness should be between 0.1 mm and 0.3 mm. And the aim of the optimization is to get the stiffest but also lightest structure.
I want to find the optimal ratio between stiffnes and weight.
But i dont know what i should use as the design responses and as the optimization constraints.
