Abaqus springs: output forces and dispalcements
MariosK
Geotechnical
Oct 13, 2023
3
Dear all. I simulate soil-pile interaction as a beam element for the pile and distributed springs along the pile to represent the soil. The springs are applied along the x, y and z directions at every node of the pile, while I have prescribed a nonlinear behaviour for the springs. My question is how can I get the output forces of springs at a certain node and a certain direction?. When I ask for S11 (i.e. spring force) and E11 (i.e. spring displacement) for an element, I get one value only. In fact, I would expect to get three different values, one for each x, y and z directions. Is there any way to decompose the output S11 and E11 to the three directions? Also, an element consist of several nodes. Would I be able to get the force applied on a certain node and not the one of the element?
Spring elements (even nonllinear) can deform only axially and thus only S11 and E11 are supported (they are defined not in the global X direction but in the axial direction of each spring so those are local coordinates).
Thank you for your reply. I am aware of your comment. My question is how can I see the the forces of three different springs that apply on the same node along the x, y and z directions. In other words, I want the force and displacement in the local coordinate system for every of the three springs.
S11 and E11 should be sufficient since it will be:
- force and displacement in the axial direction of the spring acting in the X direction
- force and displacement in the axial direction of the spring acting in the Y direction
- force and displacement in the axial direction of the spring acting in the Z direction
Thank you for your response. Indeed, I can now see that I get the counterparts for each spring element.
