jball1
- Nov 4, 2014
- 77
I will be doing an analysis of the torque-tension test of a multi-fastener bolted joint. I plan on varying multiple factors in order to determine their effect on the nut factor (which I expect to vary from bolt to bolt). This will be a very large model (fastener threads will be modeled, etc). I plan on applying the torque to the heads of the fasteners one by one to simulate the assembly sequence. I have two questions - first of all, would this be considered a "dynamic analysis"? The response of the model will vary over time, as the fasteners are sequentially torqued, which makes me think it would be considered dynamic? Also, would Abaqus Standard or Abaqus Explicit be better for this analysis? All of my experience has been in Abaqus Standard, and from what I understand, Abaqus Standard can do Low-Speed nonlinear dynamic analyses.
Thank you so much for your input!
