Dear experts;
I want to do a wear simulation incorporating the UMESHMOTION subroutine.
I have tried the simple model to model the wear in Abaqus, but I still stuck to produce wear and get the wear volume. I want to try the simple geometry.
The idea is , a rotating cylinder is loaded onto a flat surface so that this will give the contact between two body.
Then will generate wear on the surface. Maybe from your experience you can help me. Here I attached the the file related
the subroutine
Model .cae
I really hope the experts here can solve my problem. Thank you
the subroutine
http://files.engineering.com/getfile.aspx?folder=32f53da9-3e52-4f09-9bf6-58ae20a068b2&file=test2.for
Model .cae
