aborted with system error code 1073741819 1
Ajith Kurian Baby
53
I was trying to simulate a wear problem with mesh motion subroutine. the job ran for 1 increment after which it aborted with an error. I refined mesh with coarse size but still showing error. please help me to rectify this issue.
The executable standard.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
Thanks for your time . Can u share the modified file
Did you switch master and slave surface?
I made these changes in newer version of Abaqus than yours so you wouldn’t be able to open my cae file. But I can share the input file if you want.
Yes, I used the option named "Switch surfaces". It turns the master surface into slave surface and vice versa.
can u help me to correct my subroutine. Its showing no compilation error but whenever its turned on job gets aborted "The executable standard.exe aborted with system error code 1073741819".[URL unfurl="true"]https://res.cloudinary.com/engineering-com/raw/upload/v1586328372/tips/New_Text_Document_2_bu1ct4.txt[/url][URL unfurl="true"]https://res.cloudinary.com/engineering-com/raw/upload/v1586328389/tips/code_ipa5un.txt[/url]
