About basement parking lot heating
wufi2004
42
Can i use hot water/fan heater in garage ? I have hotwater from rooftop. Mostly for garage heating, what heater is better?
But i didn;t find this device on net. Can u give me some idea?
Wufi
40 cars in a basement garage
I take it you are you ventilating this space?
If not then prepare to die by carbon monoxide poisoning.
In the UK we would have to ventilate to a constant rate of 6ac/hr and go to high speed (10ac/hr) if initiated by either a carbon monoxide detector or a fire alarm.
The fans would need to be fire rated at 300C for an hour and the system would need to be in 2 parts (we assume this means run/standby plant)
Ciao
Friar Tuck of Sherwood
My ACH is around 7.Is that good? I'll use CO detectors,also.
Thanks!
Depends on the local codes
Look in ASHRAE, they give a rate per vehicle or per HP
