As per the API 610 standard Table H.1 material class for pump parts, for boil water shaft, it is recommended in S-6 to use the 12% chrome steel.
Due to the urgent need from our customer, I would like to use the 42CrV6 (carbon alloy SAE6140)instead of the martensitic A276 S42000 to make the new shaft. But I am worried about the corrosion problem will happened later. what about your opinion?
Thanks.
