Questions related to bidirectional CAD translation in Alias and Pro/E.
1. Config settings:
Alias help recommends the following configuration setting in Pro/E.
Do you see any issues with these setting?
IGES_OUT_ALL_SRFS_AS 128
IGES_OUT_SPL_CRVS_AS_126 YES
IGES_OUT_SPL_SRFS_AS_128 YES
IGES_OUT_MIL_D_28000 NO
IGES_OUT_TRM_SRFS_AS_143 NO
IGES_OUT_TRIM_CURVE_DEVIATION DEFAULT (What does default mean on this one?)
INTF_OUT_BLANKED_ENTITIES NO
INTF3D_OUT_EXTEND_SURFACE YES
INTF3D_OUT_FORCE_SURF_NORMALS YES
IGES_IN_106_F2_AS_SPLINE NO
IGES_IN_DWG_LINE_FONT YES
IGES_IN_DWG_PNT_ENT YES
IGES_IN_DWG_COLOR YES
FIX_BOUNDARIES_ON_IMPORT YES
How do I get to hidden config options? These two appear to be hidden.
Int_in_keep_high_deg_bspl_srfs
Iges_in_dwg_pnt_ent yes
2.Model Accuracy I really need more information on this topic.
Determine best tolerance(s) with which to build in both Alias and Creo
Determine if working in absolute vs. relative in ProE could cause issues
Determine if chosen tolerance value could affect computer performance
Determine if there is a “building” tolerance and an “import” tolerance
Determine how accuracy/tolerances are chosen
Determine the implications of tightening tolerances on “children” only (external copy geometry).
Determine tightest tolerance desired on machined parts
Determine tightest tolerance desired on Class A surface design
Determine if machined parts and Class A surfaces require same tolerance in software
i.Choose tolerance(s) based on above research for software and tooling needs
3.How do I check surface degrees/spans within pro/E
1. Config settings:
