Brian!
Until and unless I have cheap steam I won't disagree
![[wink] [wink] [wink]](/data/assets/smilies/wink.gif)
Olmedo!
The basic advantage of absorption system was (or is?) conversion of low grade energy to low grade energy. Generally electrcity is considered as high grade energy and heat as low grade energy. Conversion from high grade energy to a low grade energy is a loss. Though COP of absorption machines are almost one third that of compression machines, the net work input will be less incase of absorption system.
Some of the disadvantages
1. On LiBr-Water system, you cannot go below 5
0C chilled water temperature with the best attainable vacuum.
2. Crystallization of LiBr strong solution is a deadly problem at lower cooling water temperatures.
3. Periodic treatment and cleaning of LiBr is required.
4. Not a stand alone system. Even steam generator failure contributes to chiller downtime.
5. Foot print area is more for same capacity.
6. Not very flexible with load variations. (capacity control is not very good. (Liquid bypass from evaporator to absorber is a common practice. This shows the inefficiency of capacity control)
7. One point where I think Brian will agree with me is that, we should spend more time with an absorption machine when compared to relatively trouble free compression machine.
