I am having a lot of trouble getting a hatch in ACAD LT2006. I have followed the help menu from boundaries to individual line selection but just can't get hatches to form on my drawings.
I have checked elevation and they are all at zero.
I have changed scale of the hatch several times, basically, I have clicked on everything at least once in the hatch window.
One way I sometimes use to hatch a portion of a drawing is to use the region command. Region the section you are trying to hatch, that will make it into one object. Once regioned you can use the hatch command, use the "select object" option and select the region. That should allow you to hatch the section you want to without difficulty.
